Linking Call Manager 4.x and 7.x directory
May 13th, 2009
I have created an inter cluster trunk between CM4.x and CM 7.x . How do i get the two call managers to share directory information between each other so users on both systems can look up each other by directory name
Jaime Valencia Wed, 05/13/2009 - 17:17
  • Cisco Employee,
  • Hall of Fame,
    2011
easiest way is to integrate both systems to same LDAP
The directories are different between versions, asp and jsp, so you would need to customize your own script on a separate server to just have either 1 directory that searches both or provide both directories
If you need help on that try the Services for End Users or Services for Developers section.
java
if this helps, please rate
