NM-16ESW Solution
Answered Question
May 13th, 2009
Need to find out if this solution will work.
I want to install a NM-16ESW into a 2811 ISR. I would like to configure 16 individual VLAN interfaces and assign each physical port to one of the VLANs.
Will the router/module support that number of VLANs? Each VLAN interface will have it's own IP address in a separate network. Will I be able to successfully route between all of the different subnets using EIGRP?
Thanks.
Correct Answer by Edison Ortiz about 7 years 10 months ago
You can configure up to 256 Vlans. Your proposed design will work.
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Wed, 05/13/2009 - 14:05
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
