Dial peer issue
May 13th, 2009
I am having a problem where a call comes in and it will not match my incoming called number . dial peer. I am switching them from an old fax solution to Xmedius.
Basically if I call XXX-XXX-1734 (one of their fax numbers) it will not route to the incoming dial peer I have configured. It routes to the default dial-peer 0 and I get a slow busy signal. If I call XXX-XXX-6211, it will ring to Xmedius and faxes can be made. It only happens on the 17XX numbers. I included the config and some debugs that I ran.
thanks
chadlincoln Wed, 05/13/2009 - 14:51
  • Bronze, 100 points or more
Put this in:
dial-peer voice 70 pots
incoming called-number .
direct-inward-dial
port 0/0/0:10
dial-peer voice 71 pots
direct-inward-dial
port 0/0/0:11
Your dial-peer voice 3 looks ok, but it doesn't specify the port.
