CFS Pending Configuration
Answered Question
May 14th, 2009
When I try to close Device Manager (MDS9509) I get the message: You may have CFS pending configuration. Do you want to continue. I get this message on all 4 switches in the fabric.
Anyone who know how to fix this problem?
Correct Answer by user_4444 about 7 years 11 months ago
From the CLI on each switch run "sh cfs app" to see which applications are using CFS. Then go through each App using "sh cfs app name ivr" use the application where I have put ivr. To check the status of each App. Then run "sh cfs merge status name ivr" for each app. That should show if a merge has failed. Also try "sh cfs lock" to see what application has a possible lock on CFS.
Overall Rating: 4 (1 ratings)
Correct Answer
user_4444 Thu, 05/14/2009 - 01:36
havardmangset64 Thu, 05/14/2009 - 02:52
I found out which application that had a lock and cleared the lock fra Device manager
Trending Topics: Storage Networking
