Enable extension mobility by default in auto-registration?
Answered Question
May 14th, 2009
I want to auto-register a lot of phones, and have them boot up with extension mobility enabled by default. I can get them to register and display the EM service URL, but because the enable extension mobility check box on the phone config is not checked, the user can't log in.
I looked at the Enterprise and Service parameters, and at phone profiles but none of them addressed enabling EM by default.
Do you guys have any suggestions? Have I missed something obvious here? This CUCM7.0 BTW.
Tim
Correct Answer by Jaime Valencia about 7 years 11 months ago
Unfortunately it's not that you missed something, but that it's not possible to enable EM on phones on autoregistration.
Once they autoregister you can update phones and check the box via BAT
java
if this helps, please rate
Overall Rating: 4 (1 ratings)
Correct Answer
Jaime Valencia Thu, 05/14/2009 - 07:55
  • Cisco Employee,
  • Hall of Fame,
    2011
java
