Split Tunnel with Remote Access VPN
May 14th, 2009
Hi all,
I have a remote VPN to an ASA 5510 and I want to enable teh split tunnel so teh VPN client can access its own LAN as well when connected with VPN.
I have made the policies as described by Cisco , but nada !!!!
It is not working. I mean VPN works fine , but the Local LAn access does not.
I am attaching teh config!
group-policy RMTVPN internal
group-policy RMTVPN attributes
split-tunnel-policy excludespecified
default-group-policy RMTVPN
vpn-idle-timeout 30
split-tunnel-network-list value Local_LAN_Access
username test_RA password CXgT6kaftedu5zxk encrypted
username test_RA attributes
vpn-idle-timeout 30
tunnel-group RMTVPN type ipsec-ra
tunnel-group RMTVPN general-attributes
address-pool vpnpool
access-list Local_LAN_Access standard permit host
Could there be some conflict in teh policies?
jjohnston1127 Thu, 05/14/2009 - 07:05
Here is how I deploy split tunnel VPNs.
1. Change the split tunnel policy to tunnelspecified.
2. Create a standard access-list called splittunnel.
3. Add the IP subnets that you need to be able to access through the VPN to access-list splittunnel.
access-list splittunnel standard permit (where = an IP subnet you need access to. Repeat that for every subnet.)
split-tunnel-policy tunnelspecified
split-tunnel-network-list value splittunnel
