WAAS error message
May 14th, 2009
Hi there,
Seeing the following syslog message every couple of mins on a WAVE-574 running 4.1.3 -
2009-05-14 11:27:00 Local0.Warning 10.37.1.5 2009 May 14 10: kernel: %WAAS-SYS-4-900000: time.c: can't update CMOS clock from 75 to 27
2009-05-14 11:28:00 Local0.Warning 10.37.1.5 2009 May 14 10: kernel: %WAAS-SYS-4-900000: time.c: can't update CMOS clock from 76 to 28
TIA,
Zach Seils Wed, 05/20/2009 - 07:51
  • Cisco Employee,
Brian,
This message means that the system clock is more than 15 minutes off from the time set by NTP. Try the following:
1. Disable NTP.
2. Set the system time with the command 'ntpdate'.
3. Enable NTP.
Zach
cwehrstedt Wed, 11/24/2010 - 12:07
I am also getting this error, and I have checked the clock on  the inline devices and the CM and all are set insync.  Any other ideas?
Brian Cartledge Thu, 11/25/2010 - 00:57
This thread is over a year old. I don't think the WAAS community existed when I posted it. FWIW we had to RMA the WAAS with this error.
