CUB-ATT Join calls
May 14th, 2009
Hi there,
Does anyone know if there is a way of joining calla via the attendant console? The product ships with a key shortcut list that shows you can hit ctsl - J to join calls but this does not work and there is nowhere within the software that says you can join calls... bring back Cisco's attendant console!
vkapoor5 Wed, 05/20/2009 - 12:31
Join merges a group of calls and the attendant into a conference. To use the join feature, you must choose the active call and other calls on the same line.
