Switch PoE (power consumption)
Answered Question
May 14th, 2009
Hi there
How much power consumption (watts) should I consider when using a 2960PoE 48 ports with 48 7911G connected to in ?
I used once an online calculator for this but I could not find it anymore..
Thanks.
Andrei.
Correct Answer by Rob Huffman about 8 years 1 month ago
Hi Andrei,
Here is the Tool I think you were looking for :)
PoE Calculator
http://tools.cisco.com/cpc/PDS.cpc
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Thu, 05/14/2009 - 04:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Andrei,
PoE Calculator
Hope this helps!
Rob
