“CAS Cannot Establish Secure Connection to CAM”
May 14th, 2009
I have a problem with NAC
"cas Can not Establish Secure Connection to CAM"
the error message in the CAS is "Encountered error.unable to connect to manager.javax.net.ssl.SSLHandshakeException: Remote host closed connection during handshake"
e.bayon Thu, 05/28/2009 - 01:07
Check the current time for CAM and CAS, it must be in 300 segs max interval of different.
Check the SSL autogenerate certified if you are used it.
