Warning message
Configuring AAR in 4.1
May 14th, 2009
Dear all,
Need ur help in configuring AAR.It will be very helpful if I get any step to step guide to configure the same.I have configure a RP and assigned an RL to it the RL consists of the ICT and the PSTN gateway.Due to Location based CAC I am not able to make more than 2 ICT calls, ideally the third call should use the PSTN to make outgoing calls.but for the third call I get error message as not enough bandwidth.I am not sure where I am making the mistake.I have enabled AAR in the System Parameters.If someone shares the step by step guide to configure it I will grateful.
Vinay
Marwan ALshawi Thu, 05/14/2009 - 04:48
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
did u configured the external number mask on ur ip phones
and did u configured the AAR prefix as required
and make sure u confugre the corect CSS for ARR to use ur RP
good luck
vinayjaiswal Thu, 05/14/2009 - 04:53
I have not configured the external number mask, will it be the DID number which i need to put here?
What has to be configured in the AAR prefix, will it be the RP for the PSTN calls.
In AAR CSS, which partitions has to be allowed.
Thanks for your fast response.
Jaime Valencia Thu, 05/14/2009 - 07:57
  • Cisco Employee,
  • Hall of Fame,
    2011
Have you enabled AAR?
It's disabled by default so even if you have the config of AAR locations, masks, external phone number masks, etc but not enabled it won't work
java
if this helps, please rate
Chris Deren Thu, 05/14/2009 - 07:59
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Assuming North American dial plan:
You need to put the 10 digit DID number under external phone number mask
You need to assign AAR Group to the DNs, the prefix on these needs to be whatever you dial for PSTN, in most cases 91
The AAR CSS needs to include the PSTN paritions, so that the call can go out to PSTN
HTH,
Chris
