IP Accounting on the Catalyst 3560
May 14th, 2009
  • Silver, 250 points or more
I have a 3560 running 12.(46)SE and According to the configuration guide, the ip accounting is not supported. Is there any version that supports this feature?
Overall Rating: 4 (1 ratings)
mahmoodmkl Thu, 05/14/2009 - 05:18
  • Gold, 750 points or more
I think it is supported in enhanced image.
Mahmood
jgreenwoodii Fri, 05/15/2009 - 11:13
Unfortunately not. Looking at the 12.2(50)SE Command Reference ip accounting is not shown.
Jonathan
Edison Ortiz Sat, 05/16/2009 - 12:22
  • Hall of Fame,
    Founding Member
"ip accounting" isn't supported on any type of Cisco switch as the traffic flow is processed in hardware and packets processed by the "ip accounting" command are software-based flows.
For traffic profiling on a low-end switch as the 3560, you will need some 3rd party application as NetFlow is supported on Cat4500 and onward.
HTH,
__
Edison.
Tshi M Mon, 05/18/2009 - 07:47
Thanks Edison,
Any application that you might recommend?
rgrd,
