wr erase equivalent in IOS XR
I am working in 12k(gsr) running 3.6.2
I did erase nvram without the format option and did not delete the startup config, i reloaded the box and it came back by the config, i am worried if i use the format option it might cause other problems, are you 100% sure as i am in a production router that this command will delete the startup config?
