Set Location to devices
Answered Question
May 14th, 2009
Hi all,
We have a client with more than 1200 devices across 8 sites.
When the VoIP was deployed to this client we did not use Locations to control tha bandwith, but now we are setting QoS in WAN connection and we need assign each device to the right Location.
I know how to do it one by one, but is it possible to do this in other way in order to save some time.
Thanks a lot in advance.
Fernando.
Correct Answer by chadlincoln about 7 years 10 months ago
To do this, first make sure that the Cisco Bulk Provisioning Service is started. Go to servicability, tools, service activation. Then go back to the admin page.
Bulk administration, phones, update phones, query.
Search in such a way that it will find all phones in one specific location. Do that by finding things that they alone have in common. It could be description, device pool, etc. The click next, check the box next to location. Then select the location you want to put the phone in. Click reset phone, run immediately (which will reset each of those phones after the changes are made, so do off hours if necessary). Check Bulk Adminstration, Job Scheduler to see how it is going and if there were any errors.
Please rate if this helped.
Overall Rating: 5 (1 ratings)
Jaime Valencia Thu, 05/14/2009 - 08:02
  • Cisco Employee,
  • Hall of Fame,
    2011
Yes, use BAT for this purpose. That's the whole point of the tool, bulk updates
java
if this helps, please rate
Correct Answer
chadlincoln Thu, 05/14/2009 - 10:42
  • Bronze, 100 points or more
fjjaime09 Tue, 05/19/2009 - 01:13
Thanks a lot.. It works perfectly.
Fernando
