WAAS 502/522 upgrades
I am looking for a process to upgrade the WAAS code on WAE-502's and 522's but without being on the production network and visible to the CM where the software patch is usually distributed from. Is there a way to manually do the upgrade by popping the 502 into a 2811 router and using the external port to connect to a lab network that can see an FTP server in the lab with the WAAS code on it? I just need a way to manually do the upgrade in a lab environment.
