AS5400 dnis based, radius and different ip local pools
May 14th, 2009
Hi, Im configuring an AS5400 with E1 pri, and I have to configure the AS to incomming calls.
I have to separate the calls with different dnis based (using resource-pools) to assing differents ips to the differents customers.
Also I have to login this calls into a Radius.
Anyone have an example to do this?
paolo bevilacqua Sun, 05/17/2009 - 09:51
  • Hall of Fame,
    Founding Member
If you look in the manual, there is a feature guide with examples.
