DID remapping through CLI
Answered Question
May 14th, 2009
Hi all its me again :)
now that I have to do everything through CLI I was hoping someone might be able to help me out with what seems to be a simple configuration change. Right now I have our main line DID redirected to a blast group. I need to change that so the main DID goes into extension 600 which is our Auto Attendant. Does any one have any reference material they can send me?
Jorge
Correct Answer by Marcos Hernandez about 7 years 11 months ago
Jorge, if you are using CLI, this can be accomplished in a few steps:
1) Identify the dial-peer that has an "incoming called-number" statement with the DID in question.
2) Take note of the incoming translation profile applied to that dial peer.
3) Look for the translation rule assigned to that profile and edit the translated field with the new internal extension.
Hope this helps,
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
Overall Rating: 5 (1 ratings)
Correct Answer
Marcos Hernandez Thu, 05/14/2009 - 12:46
  • Blue, 1500 points or more
Hope this helps,
Marcos Hernandez
Cisco Systems, Inc.
jorgediaz77 Thu, 05/14/2009 - 17:15
That did it, thanks again Marcos.
For anyone else, here are the fields I changed per Marcos instructions:
dial-peer voice 3000 pots
description MainLine
translation-profile incoming MainLine_Called_4
incoming called-number 6666
direct-inward-dial
voice translation-rule 4
rule 1 /6666/ /100/
I changed rule 1 to 'rule 1 /6666/ /600/' and now all calls go to my auto attendant.
