Segregate WLAN to specific AP's?
May 14th, 2009
I'm using a 4404 WLC with 1131AG LWAPP's and I was wondering if there is a way to create a WLAN and have it only broadcast from specific APs?
I'm testing a new Wireless configuration but I don't want the WLAN going out across all of our AP's, just a select few in my own office.
Thanks!
Rob
Leo Laohoo Thu, 05/14/2009 - 15:52
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Yes you can. It's call AP Groups.
Wireless > Advanced > AP Groups.
rcoote5902_2 Fri, 05/15/2009 - 06:14
I'm running 5.1.151 - which means if I want to run a specific WLAN on say - 5 radios I have to turn it off in 95? (twice that if I have to disable it for both b/g and a)???
Seems an upgrade to 5.2 would make this easier with AP Groups. Would that be a correct assumption?
Leo Laohoo Sat, 05/16/2009 - 17:09
  • Hall of Fame,
    2017 LAN, Wireless
You can use WLAN Override, as what the previous post suggest. If want to risk it, you can upgrade to the latest version and use the AP Groups function. Whatever the decision is/will be, you'll wind up with the same result.
This will allow you to, say, to have five LAP to have a unique SSID while the others don't.
Hope this helps.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
