Lan-2-Lan Tunnel, ASA to 6500 or... What's the best Way to Configure?
May 14th, 2009
I'm trying to implement an L2L tunnel between our office and the data center. Currently we have an ASA 5510 in the office and a 6500 with a Firewall Service Module added on. From what I've read, the FWSM can only vpn tunnel for management. My thought is then to get another ASA and use those to establish the tunnel.
Is this the correct way of doing this, and if so, what is the best location for the ASA? My guess is to put the ASA on a DMZ and set up tunneling there? Or am I completely off on this?
Thanks in advance.
pompeychimes Wed, 05/20/2009 - 21:48
  • Bronze, 100 points or more
If you have one you can also use a router to terminate the VPN.
