Final CCNA Prep book
May 14th, 2009
  • Silver, 250 points or more
I finished my last CCNA class recently, and I want to buy a study book that will hit on the major points (vs. reading all four volumes of my CCNA class material). I thought about CCNA Exam Cram V3, but from reviews, it seems full of errors....surprisingly Lammle's fast pass book doesn't get glowing reviews either, but not have read any other reviews, I don't know if this is norm for the industry. What good book can I use for the next 2-3 weeks to brush up, go over major points for the upcoming 802 test?
Jimmy
jgagznos Fri, 05/15/2009 - 15:34
Considering that you are that close - I would recommend a different approach. Go find a reputable and legal practice test vendor to practice with. There are several of them out there to choose from. www.certguard.com has a whole list of acceptable practice test vendors. This will probably be the best use of your time over the next couple weeks.
Good Luck!
Joe
jimmysands73_2 Sun, 05/17/2009 - 08:05
I wanted a good ol'e book to read, I felt the certguard site was clunky and hard to navigate, looked like alot of propaganda leading to nothing (like socialism lol)!
Thanks for your input though.
jrosetta1 Sun, 05/17/2009 - 16:02
since you only have two to three weeks its kinda hard to say. I would say you can use the "31 Days Before Your CCNA Exam" - second edition book which was done by allan Johnson.
jimmysands73_2 Thu, 05/21/2009 - 20:10
I wound up buying Lammle Fast Pass book, its a good supplement to a regular text book, and approaches the concepts quite differently from his 700 page book.
Walter Solano Wed, 06/03/2009 - 11:43
  • Gold, 750 points or more
Hi all:
I use one book "31 days before your CCNA", this book will help you to refresh all your knowledge also I used the CBTs.
The book focused in all the topic for the 640-802 exam.
And also there is a good Lab practice at the end where you can practice all the configurations learned in CCNA.
Best regards.
Walter S.
CCNA, CCNA Voice.
