Sub Interface on Cisco ASA 5505
May 14th, 2009
Hi Experts, Can we make sub interface on Cisco ASA 5505 model and if its possible then do that interface need to be upgraded into Trunk Port. Pls explain briefly. Thanks
ray_stone Fri, 05/15/2009 - 02:14
Can you explain briefly and give an example, if possible. Thanks
kafsavant Wed, 04/24/2013 - 06:27
I have been working on a configuration in which I wanted to do subinterfaces as well.  I found that you can not create them even with having a security plus license.
Keith
Jouni Forss Wed, 04/24/2013 - 06:31
To my understanding you only configure Vlan interfaces on the ASA5505 just like a L3 Switch.
For example
interface Vlan10
nameif LAN
security-level 100
ip add 10.10.10.1 255.255.255.0
interface Ethernet0/1
switcport access vlan 10
Then you either make physical ports on the ASA5505 as Access Mode ports on that Vlan ID or configure a physical interface as a Trunk
Configuring the Trunk will require the Security Plus License.
- Jouni
