Error while telnet to ACE module!!!
May 14th, 2009
Hi ,
I am not able to telnet to my ace module please see the error/msg i see when i try to login:-
[Switch6500]$ telnet acemod2
Trying 10.10.10.2.
Connected to acemod2.asia.com
acemod2 login: admin
Password:
Context not found, called API timed out
Trying 10.10.10.2....
Connected to acemod2.asia.com.
Escape character is '^]'.
Error: context name (id:0) cannot be determined.
Any help on this will be highly appriciated.
Sum.
dario.didio Thu, 05/14/2009 - 23:29
  • Silver, 250 points or more
are you trying to telnet the Admin context or another context?
Can you try to access it via the C6500?
use following command from the supervisor of your C6500:
session slot "slot number of ACE module" processor 0
Does this work?
sumaiyausa Fri, 05/15/2009 - 01:00
hi,
yes this works. Console works fine as well. In regards to telnet it was working fine before but dont know it stopped working now.
Reg,
Sum.
litrenta Tue, 05/19/2009 - 11:32
  • Cisco Employee,
This is most likely a result of aclmerge process pegging cpu. from console do:
show proc cpu | inc aclmerged
see if processes are high.
aclmerge performance was improved in A2(2.x) code
sumaiyausa Wed, 10/28/2009 - 01:47
Hi Letrenta,
Now I am facing the issue while try to get into the ACE from cat 6500 switch.
C6509#session slot 2 processor 0
What can i do now???
Sum
