Debug mmoip send email
May 15th, 2009
i am trying to configure store and forward fax, but the problem is that the email is not sent.
"Debug mta send all" and "Debug mmoip send email [email protected]" do not show any output.
Best regards,
b.hsu Thu, 05/21/2009 - 12:51
The debug mmoip send email address command does not display anything to the screen itself, but it is very useful. It uses the router as an SMTP client to send an email to the address given in the debug command. The email has the subject defined in the configuration and is from "mspi Test User". It contains a text attachment with the line, "This is a test email message sent via Cisco Powered Libretto Faxmail."
markotisler Thu, 05/21/2009 - 21:45
Solved this by using debug fax foip command, which indicated domain name error when sending the email.
