05-15-2009 01:21 AM - edited 03-18-2019 11:03 PM
I am setting up a lab whereby I am installing CUCM and CUPS in VMWare. I have already installed CUCM and it is working fine. If I will install the CUPS in VMWare, will it work or will I need CUPS license to make it work with the CUCM?
Thanks and much appreciate for a reply if anyone has done this configuration.
Chandarsen
05-15-2009 04:49 AM
No license is needed. Once CUPS detects VMWare, it'll use the demo license built-in, which limited to single server (no HA).
Michael
05-18-2009 03:11 AM
Michael,
Thank you very much. I will try to install using the VMWARE.
Chandrasen
