Historical Utilization ports Report
May 15th, 2009
Hi all,
I need know if is possible generate a report with historical data of utilization ports
Is possible?
Thanks a lot
Joe Clarke Fri, 05/15/2009 - 09:35
I assume you're referring to something in LMS. Yes, this is possible if you are using the Health and Utilization Monitor add-on to LMS. The reports can be defined under HUM > Reports > Report Management.
j-fragoso Sun, 05/17/2009 - 23:43
Thanks for your answer.
Is possible generate this report without HUM?
Best Regards,
