Translation patterns Issue ???
May 15th, 2009
Hi, we are using translation patterns for our 50 sites, by using *036, which translate to (02345566) and *037 transalate to (03344667). Now the Telephone provider changed the numbers nation wide and increased the 8 digits to 10. Now (02345566) number will be changed to (023 99 45566) and same for the 2nd number. I tried to change the number in Call Manager--translation pattern--Called Party Transform Mask, and I thought it would work! but when I dial *036, it does not go through and and get usual message! when I change this to an old number, then it does go through! Can some one help me regarding this issue!
Also I checked the dial-peers in the router! which are:
dial-peer voice 1 pots
destination-pattern 9T
progress_ind alert enable 8
direct-inward-dial
port 0/0/0:15
dial-peer voice 2 voip
destination-pattern 850.
session target ipv4:192.168.XXX.XXX
codec g711ulaw
no vad
dial-peer voice 3 voip
destination-pattern 01..
session target ipv4:192.168.XXXX
codec g711ulaw
no vad
dial-peer voice 4 voip
preference 1
codec g711ulaw
no vad
Any reply will be appreciated!
sebastiandm Fri, 05/15/2009 - 06:49
What happens if you dial the number manually from one of the phones onsite ? Have you checked your route patterns, maybe you have a match which is being blocked. You could also try dialling the number directly from the gateway using csim start if h.323.
wahidayat007 Fri, 05/15/2009 - 07:19
Yes, when I dial manually it automatically decrease the digit from 10 to 8, I mean it does not show the last two digit in the number on the IP phone screen. It seems to me that I need to upgrade the dial plan software in Call Manger to support 10 digits>
I just use one route pattern 9.@ thats it!
Can you send me the procedure, how to dial directly from the Gateway ?
If you have any other idea, please let me know.
thanks
sebastiandm Fri, 05/15/2009 - 07:26
Seems you have a problem with your dialplan. Insert this route pattern:
9.02399XXXXX
and let me know if this works.
wahidayat007 Fri, 05/15/2009 - 08:00
Like earlier I said, I just use 9.@, which suppose to dial any number digits, like If I dial mobile numbers, it goes through, but if I dial the landline new provisioned numbers, it does not go through!
what difference would that make (9.02399XXXXX) ?
wahidayat007 Wed, 05/20/2009 - 00:26
Well, I tried the above route pattern (9.02399XXXXX) it worked with 10 digits, but I got issue with this, Now the 8 digits remote numbers can't be dialed!
9.@ means you can dial anywhere and any number of digits, but in my case it the first the translations patterns is working fine, but when I change the called party number from 8 digits to 10 digits, I get error message. Any help will be appreciated!
