05-15-2009 02:59 AM
We try to integrate the ACE module into ciscoworks.
But after having cisoworks fetch the config file of the ace module, it results into this error:
CM0056 Config fetch failed for Cause: CM0204 Could not create DeviceContext for 4452 Cause:
CM0206 Could not get the config transport implementation for x.x.x.x
Cause: UNKNOWN Action: Check if required device packages are available in RME.
Action: Check if protocol is supported by device and required device package is installed.
The error talks about a certain DEVICE PACKAGE. Is it available for ACE integration in Ciscoworks ?
Wim
05-15-2009 09:37 AM
It depends on the specific sysObjectID for this device as to whether or not it's actually supported in RME. However, you can get the latest RME device packages from Common Services > Software Center > Device Update, or from Cisco.com at http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-rme .
05-17-2009 11:30 PM
Thanks for your information!
I think that ACE20-K9 module is not yet supported, since the latest ACE.RME dated from 19/01/09 only support the devices: ACE10K9 and ACE4710K9
05-17-2009 11:56 PM
No, the ACE20 should be supported. However, as I said, it depends on the sysObjectID of your specific device.
05-18-2009 10:08 PM
Can we monitor & prepare reports about the ACE connections and probe using RME?
Abd Alqader
05-19-2009 08:28 AM
You need to start a new thread for your question.
