ways of load balancing to WAN
May 15th, 2009
Hi all, if I wanted to load balance traffic out of my wan using 2 routers, how would this be done, I know that they routing protocol will load balance but how would I send the traffic to the 2 routers,
are the 2 options, 2 static equal cost routes, and glbp?
cheers
Carl
Overall Rating: 3.5 (2 ratings)
cisco_lad2004 Fri, 05/15/2009 - 03:12
  • Gold, 750 points or more
Equal path routing and GLBP would both achieve what you want.
Etherchannel is also an option.
Sam
jgreenwoodii Fri, 05/15/2009 - 10:19
Maybe I'm reading to much into the question but curious if you have 2 WAN circuits terminating on 2 individual routers or is the topology using 2 routers connected to a Single Wan Router?
Jonathan
