Personal directory
Tomas Chott Mon, 05/18/2009 - 11:04
  • Bronze, 100 points or more
Hello Paolo,
you can this:
1/ with SPA9000 use Corporate Directory, this is list of All phones in SPA9000 System
2/ use Personal Directory, this directory is save in phone, solo for every Phone
3/ with SPA922, 942, 962 and 525G you can use LDAP Directory, for set look at this document https://www.myciscocommunity.com/docs/DOC-1251
Tomas
I don't know what you mean with:
I'm searching for a solutions for have a shared "address book" on all phones, but I don't find the Corporate Directory.
I already know LDAP Directory but I don't want to setup it on my PDC or setup another machine to use the OpenLDAP.
Best Regards
Patrick Born Tue, 05/19/2009 - 04:27
  • Cisco Employee,
Hi Paolo,
The corporate directory is an automatically created directory. The SPA9000 builds up the directory based on the registered phones. Access the corporate directory as follows:
A. On a SPA9x2 phone press the "Directory" soft key [second from the left, under the display]
B. The Directory page will display:
1 New Entry
2. Corporate Directory
C. Press 2 or scroll down and select Corporate Directory
D. The phone will access the SPA9000 and display all registered phones
Patrick
