Route pattern 9.811 Need to dial faster, avoid or shorten digit timeout
Answered Question
I have a route pattern that needs to dial 811 on an outside line. 9.811 works, but when the user dials it, they have to wait a long time for the connection to be made. If I enter patter 9.811# and they enter the # it goes right away, but if they forget the # they get an invalid number.
1) How can I speed it up, is urgent priority the only way?
2) How can I have the pattern accept 9.811 and 9.811# also? Do I need to set up two route patterns?
Thanks in advance,
Gene
Correct Answer by Jaime Valencia about 7 years 10 months ago
You get IDT if you have overlapping numbers (It's expected and documented), the solutions are:
a) create a non-overlapping dial plan
b) keep overlapping but check urgent priority
those are the only options to have it go immediately
java
if this helps, please rate
Overall Rating: 5 (2 ratings)
KonradStepniewski Fri, 05/15/2009 - 05:13
  • Silver, 250 points or more
1. Yes, as soon as it matched will go through when urgent priority is marked.
2. Yep, setup 2 patterns.
Correct Answer
Jaime Valencia Fri, 05/15/2009 - 05:57
  • Cisco Employee,
  • Hall of Fame,
    2011
java
