RECEIVING SPAM AFTER MIGRATED TO ASA
May 15th, 2009
Hi all,
I am facing a problem. Recentely we migrated a firewall to the ASA 5510. After of implementations we are receiving spam a lot. The curios is that if we make a roll back to previous firewall, the spam stops of received.
We have a mail scanner on dmz and the mail server is placed in inside network.
Someone know what can I do to fix this?
ASA Version 8.0(4)
access-list outside_in extended permit tcp any host x.x.x.x eq www
access-list outside_in extended permit object-group xvxvx any host x.x.x.x eq domain
access-list outside_in extended permit udp any host x.x.x.x eq domain inactive
access-list outside_in extended permit tcp any host x.x.x.x eq ftp
access-list outside_in extended permit icmp any any
access-list outside_in extended permit tcp any interface outside eq smtp
nat-control
global (outside) 1 interface
nat (dmz) 0 access-list dmz_nat0_outbound outside
nat (dmz) 1 0.0.0.0 0.0.0.0
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
static (dmz,outside) tcp interface smtp Mail_Scanner smtp netmask 255.255.255.255
static (inside,outside) udp interface domain DNS_SERVER domain netmask 255.255.255.255
static (inside,outside) tcp interface lotusnotes Notes_Server lotusnotes netmask 255.255.255.255
static (inside,outside) tcp interface www WEBServer www netmask 255.255.255.255
static (inside,outside) udp interface 3050 FTP_Server 3050 netmask 255.255.255.255
static (inside,outside) tcp interface 3050 FTP_Server 3050 netmask 255.255.255.255
static (inside,outsidE) tcp interface ftp FTP_Server ftp netmask 255.255.255.255
static (inside,outside) tcp x.x.x.X www XXX 1700 netmask 255.255.255.255
static (inside,outside) tcp interface 3200 XXXX 3200 netmask 255.255.255.255
static (inside,outside) tcp interface 3300 XXXX 3300 netmask 255.255.255.255
static (inside,outside) tcp interface 3389 XXXX 3389 netmask 255.255.255.255
access-group outside_incomining in interface outside
access-group dmz_access_in in interface dmz
access-group inside_access_in in interface inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect icmp
It could be that in your configureation you are allowing outside SMTP connections to the outside interface IP address of the ASA.
You have globally NATT'd the inside SMTP and the DMZ mail scanner to the SAME outside IP address.
When an outside mail server tries to deliver an email on SMTP - IF the inside mail server already has an outbound connection to the internet, the ASA will forward the connection onto the inside email server and not the DMZ mail scanner.
HTH>
