How to debug ACE FT Sync Problems ?
May 15th, 2009
in one of our contexts we have a sync problem on the standby unit.
"sh ft group detail" gives
"Running cfg sync status : Error on Standby device when applying configuration file replicated from active", while "Startup cfg sync status" is OK.
"sh crypto files" and "dir disk0:" produce the same output on both ACE units.
How can we analyze the problem ?
Gilles Dufour Mon, 05/18/2009 - 00:36
Get a 'show ft history ha_mgr' and 'show ft history cfg' and 'show ft history ha_dp' after a failure.
The reason for the problem should be there.
Gilles Dufour Tue, 05/19/2009 - 04:42
We need the same info from the standby.
Also do not forget the 'show ft history cfg' as it is most probably the one containing the error.
