05-15-2009 06:12 AM - edited 03-06-2019 05:44 AM
I am receiving an "IP routing not enabled error." How can this be fixed?
Solved! Go to Solution.
05-15-2009 06:19 AM
try
conf t
ip routing
becareful, if you have a gateway set you will loose remote connectivity to teh box.
Sam
05-15-2009 06:19 AM
try
conf t
ip routing
Sam
05-15-2009 07:02 AM
I can't believe this wasn't covered on the CCNA certification exam.
05-15-2009 07:24 AM
brace yourself, it does not stop there...and that is the beauty of it :-)
05-15-2009 07:26 AM
What is go good about not learning the fundamentals on the CCNA exam?
05-15-2009 07:38 AM
What I mean is that the learning process in this filed has no limit, be it for exams or real life.
