Some boxes reference enable secret, some do not
Kevin Melton
Level 2
Level 2
I am working at a client site today that uses a Cisco ACS server via AAA to authenticate users. TACACS is configured and when an admin ssh's to a box on the network, the box queries TACACS which in turn queries Active Directory to authenticate the user.
We came up with a policy that would grant priveleged mode to the authenticated user, and then they would have to enter the "enable secret" password locally on the box to enter into PRIV EXEC mode.
For some reason, most of our Cisco devices work fine this way. But we have a handful that will authenticate directly to PRIV EXEC mode after TACACS authentication without prompting the admin for the enable secret password.
I have inspected the configurations on the devices that do not challenge for the enable secret, and they have the same aaa command configured on them as the ones that do challenge for the enable secret password.
Here is an example configuration:
aaa new-model
aaa authentication login default group tacacs+ line
aaa authentication login vty-access group tacacs+ local
aaa authentication enable default enable
aaa authorization config-commands
aaa authorization exec vty-access group tacacs+ local none
aaa authorization commands 0 default group tacacs+ none
aaa authorization commands 1 default group tacacs+ none
aaa authorization commands 2 default group tacacs+ none
aaa authorization commands 3 default group tacacs+ none
aaa authorization commands 4 default group tacacs+ none
aaa authorization commands 5 default group tacacs+ none
aaa authorization commands 6 default group tacacs+ none
aaa authorization commands 7 default group tacacs+ none
aaa authorization commands 8 default group tacacs+ none
aaa authorization commands 9 default group tacacs+ none
aaa authorization commands 10 default group tacacs+ none
aaa authorization commands 11 default group tacacs+ none
aaa authorization commands 12 default group tacacs+ none
aaa authorization commands 13 default group tacacs+ none
aaa authorization commands 14 default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
aaa authorization network default group tacacs+ none
Collin Clark
Do the VTY's have-
privilege level 15
That's typically where you get PRIV EXEC mode from.
We have the following commands configured on our vty lines:
line vty 0 4
session-timeout 30
access-class telnet-access in
exec-timeout 15 0
authorization commands 15 vty-access
logging synchronous
login authentication vty-access
transport input telnet ssh
line vty 5 15
session-timeout 30
exec-timeout 15 0
we tried negating the
"authorization commands 15 vty-access" but to no avail.
At that point we were authenticating to TACACS fine and then getting prompted like we wanted. But for some reason( witnessed during debug aaa auth) we were getting password mismatches. We re-entered our enable secret password and tried again, but kept on getting password no match and then "Access Denied".
Perhaps you can help out and tell me what should be configured on the VTY lines so that it will reference the enable secret?
What you have looks good. Does everything look OK in ACS?
Kevin
My guess at this point is that the issue is not on the router but is in ACS. Can you check on the configuration in ACS of a couple of the devices that put authenticated users directly into privilege mode? Do these devices have the shell exe checked (and do they give privilege level 15)?
The command on the router that works with this is the command:
I would suggest a slight revision of this to make it like:
aaa authorization exec vty-access group tacacs+ if-authenticated
Rick
Rick
