How to Determine what SHIM's are enable on Unix
May 15th, 2009
For CSA - Can someone post how to check what SHIM's are enabled on Unix boxes?
Secondarily How to Disable individual SHIM's on Unix?
smalkeric Thu, 05/21/2009 - 13:12
To allow users to select whether or not to enable the network shim themselves, you would create kits as not-quiet installations. (Do not select the Quiet install checkbox.) This way, users are prompted to enable the network shim during the agent installation.
"network shim optional" section in the below URL:
