Warning message
help w/ topology
May 15th, 2009
can anyone draw a network topology for this one or help me understand it , I could nto figure it out... Thanks
# sho ip eirgrp topology
IP-Eigrp topology table for AS(100)/ID(192.168.2.21)
P 192.168..2.0/24, 1 successors, FD is 2789456
via 192.168.8.22 (2707456/2195456), s0/0
via 192.168.8.18 (2707456/2195456), s0/2
P 192.168.8.20/30, 1 successors, FD is 2705656
via connected, s0/0
P 192.168.8.16/30, 1 successors, FD is 2187456
via connected, s0/2
P 192.168.8.24/30, 1 successors, FD is 2276456
Overall Rating: 5 (1 ratings)
Jon Marshall Fri, 05/15/2009 - 09:05
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The router has 2 serial interfaces -
s0/0 IP 192.168.8.21
s0/2 IP 192.168.8.17
the serial interfaces are P2P connections to another device(s)
other end of P2P connections are
s0/0 192.168.8.21 -> P2P -> 192.168.8.22
s0/2 192.168.8.17 -> P2P -> 192.168.8.18
for this router to get to networks 192.168.2.0/24 & 192.168.4.0/24 it can use either P2P link.
Edit - you don't actually know whether there is one router or 2 routers at the other end of the P2P's.
Jon
