CUCM6.x mobility feature - Avaya EC500
cjrchoi11
Avaya EC500 is easy way to enable/disable the Mobility feature and the customer wants to know any way in Cisco. The customer don't like the way via WEB interface or MVA which is more steps than Avaya EC500
Any way in Cisco or road map?
Thanks advance,
chadlincoln
Level 3
Level 3
In CCM 7, you can disable mobility from the phone. It is also on a schedule, so you don't get the 2 AM phone calls if you didn't shut it off before you left.
Please rate if this helped.
chadlincoln
Level 3
Level 3
