HELP - Site-to-Site VPN recreated every time I deploy some configuration
May 15th, 2009
Hi everybody,
I have many site-to-site VPNs configured in my ASA. This device is added in CSM version 3.1.0.
Every time that I deploy some configuration to ASA, like static route configuration or ACLs, the system had a abnormal behaviour, recreating the last configuration of site-to-site VPN.
For instance, consider the configuration that follows:
crypto map VPNTEST 1 match address TEST
crypto map VPNTEST 1 set peer PEER-DBA-100.100.100.100
crypto map VPNTEST 1 set transform-set ESP-TEST
crypto map VPNTEST 1 set security-association lifetime seconds 3600
crypto map VPNTEST 1 set reverse-route
If I deploy some configuration from CSM to ASA, the next configuration of ASA will be:
crypto map VPNTEST 2 match address TEST
crypto map VPNTEST 2 set peer PEER-DBA-100.100.100.100
crypto map VPNTEST 2 set transform-set ESP-TEST
crypto map VPNTEST 2 set security-association lifetime seconds 3600
crypto map VPNTEST 2 set reverse-route
If I deploy again, another crypto map will be created, as follows:
crypto map VPNTEST 3 match address TEST
crypto map VPNTEST 3 set peer PEER-DBA-100.100.100.100
crypto map VPNTEST 3 set transform-set ESP-TEST
crypto map VPNTEST 3 set security-association lifetime seconds 3600
crypto map VPNTEST 3 set reverse-route
Does anybody knows why this happens?
J A Stuchi
handsy Mon, 05/18/2009 - 06:38
What version of ASA IOS are you running? Have you checked for bugs using Cisco bug toolkit yet?
jose.stuchi Wed, 05/20/2009 - 03:58
I'm using ASA IOS 7.2(4) version.
I looked for this error in Bug ToolKit but I didn't find any answer.
Can you help me?
J A Stuchi
