WCCP configuration
May 15th, 2009
Dearss
I am trying to configure traffic redirection for WAAS. from one side i have the WAE attached to a layer 2 switch and the default gateway is the router. by doing router on a stick. on the edge side, i have a WAE attched to a layer 3 switch where the SVI is the default gateway. so i have to configure the wccp on the switch. the topology is a hub and smoke topology and running OSPF with the spokes. configuring WCCP on a switch is different than a router and i want the traffic on the link where the WAE is installed. It is a little tricky.
Any suggestions kindly, check my diagram in the attachment
ropethic Fri, 05/15/2009 - 12:24
  • Silver, 250 points or more
On a switch you will use layer 2 redirection.
On the WAE configure as follows:
wccp tcp-promiscuous router-list 1 L2-redirect mask-assign
On the switch place ip wccp 61 redirect in your client facing interfaces
and ip wccp 62 redirect in uplink to wan
eliesbat25 Fri, 05/15/2009 - 22:18
L2 redirection on the switch connected to the edge WAE. the configuration will be:
wccp web-cash redirect in under the user SVI?
wccp tcp-promiscuous router-list 1 L2-redirect mask-assign on the core WAE.
ip wccp 61 under the subinterface of the router connected to the user?
ip wccp 62 redirect on serial interface from the core side?
please clarify and if you have a document that will help me understand well the configuration
