cannot lock rf frequency
May 15th, 2009
I have an 1131ag wap that seems to be having trouble enabling the radio interfaces. This is the error I get on bootup:
000015: *Apr 7 23:30:16.807: %DOT11-6-FREQ_SCAN: Interface Dot11Radio0, Scannin
g frequencies for 13 seconds
000016: *Apr 7 23:30:16.830: %DOT11-6-FREQ_SCAN: Interface Dot11Radio0, Scannin
g frequencies for 24 seconds
000017: *Apr 7 23:30:17.002: %DOT11-3-RADIO_RF_LO: Interface Dot11Radio0 Radio
cannot lock RF freq
000018: *Apr 7 23:30:17.215: %LINEPROTO-5-UPDOWN: Line protocol on Interface Do
t11Radio0, changed state to down
000019: *Apr 7 23:30:18.214: %LINK-3-UPDOWN: Interface BVI1, changed state to d
own
Both dot11radio0 and dot11radio1 cannot lock rf frequencies.
I have tried reinstalling the ios. Is there anything else I can do?
Dan.
jeff.kish Fri, 05/15/2009 - 10:57
  • Silver, 250 points or more
Try locking the frequencies manually. Run the following config:
conf t
int Dot11Radio0
channel X
int Dot11Radio1
channel Y
Choose channels with X and Y. It's generally best to hard-code your channels anyway. But as for why the AP can't lock frequencies on its own, maybe there's just too much interference in the area?
Jeff
danletkeman Fri, 05/15/2009 - 12:30
Yes I have tried that as well. But no matter what I do the interface says it is "reset"
Dot11Radio0 is reset, line protocol is down
Hardware is 802.11G Radio, address is 0015.2c49.b4a0 (bia 0015.2c49.b4a0)
MTU 1500 bytes, BW 54000 Kbit, DLY 1000 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Last input never, output never, output hang never
Input queue: 0/1127/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/30 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 6 interface resets
0 lost carrier, 0 no carrier
mscherting Wed, 05/20/2009 - 14:14
I've seen this on dual radio 1131s with PoE. You have to tell it where it's getting power; injector or PoE port. Get into config mode & type:
power ?
danletkeman Wed, 05/20/2009 - 15:40
I just cannot seem to get it working. I have tried every single possible combination. Using a poe switch with or without the power commands, using a power injector and using a power supply.
Any other ideas?
jeff.kish Thu, 05/21/2009 - 05:22
Can you post your AP config? Maybe there's something in there that will give us a clue about what's up.
danletkeman Thu, 05/21/2009 - 14:30
Very basic config:
version 12.4
no service pad
service password-encryption
service sequence-numbers
hostname ap
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
led display alternate
dot11 ssid corporate
vlan 20
authentication open
authentication shared
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii 7 11111111111111
dot11 network-map
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 20 mode ciphers aes-ccm
ssid corporate
mbssid
station-role root
interface Dot11Radio0.20
encapsulation dot1Q 20 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
ssid corporate
dfs band 3 block
mbssid
channel dfs
station-role root
interface Dot11Radio1.20
no ip route-cache
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 160 in
interface FastEthernet0.20
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.75.55 255.255.255.0
no ip route-cache
ip default-gateway 192.168.75.200
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server view dot11view ieee802dot11 included
snmp-server community public RO
bridge 1 route ip
I've tried a write erase and setup everything from scratch and still same result.
Dan.
Vinay Saini Mon, 06/08/2009 - 04:51
  • Cisco Employee,
Hii ,
Have you raised any case with the Cisco support on this ?
Seems like some bug .
Vinay
tomathur Sat, 06/27/2009 - 16:34
Hi Dan,
Can you please let me know the software version on the access point? Some software images have a bug which causes this issue.The bug may be CSCsd44941 which applies to 12.3(08)JA 12.3(07)JA 12.3(04)JA 12.3(02)JA etc.
Cheers,
Manish
danletkeman Sat, 06/27/2009 - 19:38
Currently it has 12.4(10b)JDA. I have tried a few different versions, but the error persists.
tomathur Mon, 06/29/2009 - 00:15
Hi Dan,
This issue is a bit complicated.The
fix consists of a software change to a hardware configuration register. You will have to get the device RMAed from Cisco.
Cheers,
Manish
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
