Changing Softkey Order
May 15th, 2009
Where in CCM 6.0.1 can I change the softkey order for a standard user? I would also like to add abbrdial to the softkeys for this user but is is not an option.
Jaime Valencia Fri, 05/15/2009 - 12:20
  • Cisco Employee,
  • Hall of Fame,
    2011
under softkey template option, you cannot modify std templates, so copy and rename it.
then you can modify it with the configure softkey layout option
java
if this helps, please rate
Mojo1 Fri, 05/15/2009 - 13:17
I created a copy and renamed it like you said. I wold like the abbrdial softkey and this is not an option. Since I can Create AbbrDial Numbers for the device how come there is not a key for this?
Mojo1 Fri, 05/15/2009 - 13:58
How can I add an AbbrDial softkey option if one is not listed. I thought this was a standard softkey option to put in a template.
Rob Huffman Sat, 05/16/2009 - 09:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Bill,
These type of Speeddials are accessed by keeping the Handset On-Hook, dialing the applicable Speed Dial Code (for example 15 followed by pressing the AbbrDial Softkey) the number programmed against Speed Dial 15 will then be called;
Just to clarifiy, the AbbrDial Softkey is not available in any Template :) It is inherently there when On-Hook dialing.
Hope this helps!
Rob
