Cisco 3750 switch
May 15th, 2009
We have two stacked 3750 switches that have been rebooting for several days. Is there a way to check which switch has been rebooting by checking the uptime? The show version only shows 1 uptime.
We need to make sure that we replace the bad switch.
Thanks.
rrdumag67 Fri, 05/15/2009 - 13:50
Thanks Giuseppe. The "show switch" shows both are ready.
We recently added the second switch. That's when the rebooting started happening. It could be the second switch. We can try to replace it and see what happens. Thanks for the link.
Leo Laohoo Fri, 05/15/2009 - 18:40
Can you find a crashinfo file when you do the following commands:
dir flash:
dir flash1:
If you do, can you post/attach the file?
