Installation of Rtr7000 package fails
didentx01
I am trying to install the Rtr7000, RME device package, so that we can get the configs for the 7606-S switch. From the gui we select the libswim.rme40.v1-8-4.zip, SharedDcmaIOS.RME40.v1-6-3.zip, LibInventory.RME40.v1-11-5.zip, SharedInventoryCatSwitchRME40.v1-7-4.zip, SharedInventoryRouter.RME40.v1-5-2.zip and Rtr7000.RME40.v5-4.zip. It fails with the following error "SharedSwimRtr800 Warning: SharedSwimIOS (1.11.7) Consistency check failed for base package SharedSwimRtr800"
Is this a bad package and I need to delete it?
Joe Clarke
No. This means that you are missing a dependency for SharedSwimRtr800. These kind of problems are usually found on Windows, and usually point to a bad base RME installation. This is recoverable, but you'll need to contact TAC to get the procedure.
Thanks Joe! I did not build these server but I am running into many similar issues.
