2851 Router Int config
May 15th, 2009
I inherited a nework that has a 2851 router with the following config:
interface GigabitEthernet1/0
ip address 10.50.20.1 255.255.255.0
ip virtual-reassembly
interface GigabitEthernet1/0.1
encapsulation dot1Q 1 native
ip address 10.20.10.1 255.255.255.0
interface GigabitEthernet1/0.25
encapsulation dot1Q 25
ip address 10.20.20.1 255.255.255.0
I am not clear on why the physical int is configured with an IP address since there is two logical interfaces configured under it.
Also, this is a L2/L3 router and I am not sure how to access the L2 switch part of it.
Any help would be greatly apprecaited.
Thanks in advance,
sK
Giuseppe Larosa Sun, 05/17/2009 - 11:31
  • Hall of Fame,
    Founding Member
Hello Sadik,
you are right the IP config under the main interface should be moved to a new subinterface.
You can face problems because vlan1 (as a L2 broadcast domain ) is associated to two different L3 interfaces.
But to understand what to move you need to get a complete picture of the network.
A second ip subnet can be mapped to a broadcast domain using secondary ip address
ip address x.x.x.x 255.255.255.0
ip address y.y.y.y 255.255.255.0 secondary
About the switch module:
if you post
sh ver
sh inventory
you can get help on this: depending on the type of modules they have a separate telnet session.
if with sh ip int br
you see multiple FE ports you can manage them from the router otherwise you can telnet to it (this could explain why two ip subnets are with vlan1 ..)
Hope to help
Giuseppe
