LAA with Enterprise Skill Group in ICM
Answered Question
May 15th, 2009
  • Silver, 250 points or more
Can you use a Select node with LAA and an enterprise skill group, just as you can with a skill group node?
Thanks!
Chad
Correct Answer by Chris Deren about 7 years 11 months ago
Yes, but you use a different node for the enterprise skill group, the select node is the same.
Also, when you queue to enterprise skill group you need to change the Target type of the queue node to Enterprise Skill Group.
HTH,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Sat, 05/16/2009 - 03:45
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
