IPv6 Campus Deployment experiences?
May 16th, 2009
Hi all,
Since the understanding of IPv6 itself is not a big problem anymore, I am on the search of documents how to deploy it on campus Networks.
Example: I have a building with 10 routed IPv4 /24 Subnets and want to run dual-stacked. Are there the same rules for the size of broadcast domains like v4?
Do I just subnet the same blocks of clients in v6 and route them?
I cannot find specific reading about this. Any recommendations? Best Practices?
fsebera Mon, 05/18/2009 - 11:21
With the initial release of IPv4 addresses, it was suggested to just make the subnets as large as you desired - this was back in the day you see.
Now since IPv6 has such an enormous address space, we are being told to follow the same method again.
With v6, docs suggest to make every link (lan, wan, point-to-point etc.) /64.
I did not follow this method, I followed my current v4 setup.
Also in my v4/6 lab, I used the following setup.
LAN1 /24
172:16:1::0 /120
LAN2 /24
172:16:2::0 /120
Point-to-point links /31
172:31:1::0 /127
Is this the right way ???
I am sure there are MANY ways - LOL
good Luck
bsiegenthaler Mon, 05/18/2009 - 11:59
You will be forced to use /64 for working autoconfiguration. And yes, smaller than /64 makes no sense the IPv6-Way. But for single broadcast-domain, there must be a limit for the number of hosts...
Also according to sixxs You can configure Your router this way:
ipv6 unicast-routing
interface Ethernet0/0
ipv6 address [IPv6 Prefix]/64
ipv6 enable
ipv6 nd ra-interval 60
ipv6 nd ra-lifetime 180
ipv6 nd prefix-advertisement [IPv6 Prefix]/64 360 60 autoconfig
