VPN Problem
May 16th, 2009
  • Bronze, 100 points or more
Dears ,
I'm creating a VPN Tunnel with Sonice Wall firewall and Í'm getting so many VPN associations as given below and the number is incresing
Albinali#sh crypto isakmp sa
dst src state conn-id slot status
Y.Y.Y.Y X.X.X.X QM_IDLE 24 0 ACTIVE
Y.Y.Y.Y X.X.X.X QM_IDLE 23 0 ACTIVE
Y.Y.Y.Y X.X.X.X QM_IDLE 22 0 ACTIVE
Y.Y.Y.Y X.X.X.X QM_IDLE 21 0 ACTIVE
Y.Y.Y.Y X.X.X.X QM_IDLE 20 0 ACTIVE
Y.Y.Y.Y X.X.X.X QM_IDLE 19 0 ACTIVE
Y.Y.Y.Y X.X.X.X QM_IDLE 18 0 ACTIVE
Y.Y.Y.Y X.X.X.X QM_IDLE 17 0 ACTIVE
Y.Y.Y.Y X.X.X.X QM_IDLE 16 0 ACTIVE
Y.Y.Y.Y X.X.X.X QM_IDLE 15 0 ACTIVE
Y.Y.Y.Y X.X.X.X QM_IDLE 14 0 ACTIVE
Y.Y.Y.Y X.X.X.X QM_IDLE 13 0 ACTIVE
Y.Y.Y.Y X.X.X.X QM_IDLE 12 0 ACTIVE
Y.Y.Y.Y X.X.X.X QM_IDLE 11 0 ACTIVE
Y.Y.Y.Y X.X.X.X QM_IDLE 10 0 ACTIVE
Y.Y.Y.Y X.X.X.X QM_IDLE 9 0 ACTIVE
Y.Y.Y.Y X.X.X.X QM_IDLE 8 0 ACTIVE
Y.Y.Y.Y X.X.X.X QM_IDLE 7 0 ACTIVE
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key [email protected] address 212.76.83.50
crypto isakmp identity hostname
crypto isakmp ccm
crypto ipsec transform-set vpn esp-3des esp-sha-hmac
crypto identity hostname
crypto map VPN_MAP 1 ipsec-isakmp
set peer X.X.X.X
set security-association lifetime seconds 86400
set transform-set vpn
match address vpn
interface FastEthernet0/0
description Towards_LAN
ip address 172.21.81.1 255.255.255.224 secondary
ip address 192.168.5.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description Towards_PoE_Wireless_Injector
ip address Y.Y.Y.Y 255.255.255.248
ip nat outside
speed 100
full-duplex
crypto map VPN_MAP
ip classless
ip route 0.0.0.0 0.0.0.0 172.21.80.1
no ip http server
ip http access-class 23
no ip http secure-server
ip nat inside source list 123 interface FastEthernet0/1 overload
ip access-list extended vpn
permit ip 192.168.5.0 0.0.0.255 190.10.0.0 0.0.255.255
