Upgrade Callmanager 7.0.1 to 7.0.2
Answered Question
Hi!
I have a problem with upgrade UCM to recent version. I have fresh UCM 7.0.1.11000-2. I downloaded UCM upgrade UCSInstall_UCOS_7.0.2.20000-5.sgn.iso (both files). When I tryed to upgrade UCM, I got this error "The version number inside the selected upgrade does not match the filename". How can I fix this error? Should I first upgrade UCM to SU1a release?
Correct Answer by Rob Huffman about 8 years 1 week ago
Hi Alexander,
This type of error can be caused when combining the 2.iso files. Check that the "final" filename is correct :)
Because of its size, the UCSInstall iso file, UCOS_7.0.2.20000-5.sgn.iso, comprises two parts:
• UCSInstall_UCOS_7.0.2.20000-5.sgn.iso_part1of2
• UCSInstall_UCOS_7.0.2.20000-5.sgn.iso_part2of2
Procedure
Step 1 From www.cisco.com, download the two UCSInstall files.
Step 2 To reunite the two parts of the file, execute one of the following command.
Note Because the 7.0.2.20000-5 build is a nonbootable ISO, it proves useful only for upgrades. You cannot use it for new installations.
a. If you have a Unix/Linux system, cut and paste the following command from this document into the CLI to combine the two parts:
cat UCSInstall_UCOS_7.0.2.20000-5.sgn.iso_part1of2 UCSInstall_UCOS_7.0.2.20000-5.sgn.iso_part2of2 > UCSInstall_UCOS_7.0.2.20000-5.sgn.iso
b. If you have a Windows system, cut and paste the following command from this document into the
command prompt (cmd.exe) to combine the two parts:
COPY /B UCSInstall_UCOS_7.0.2.20000-5.sgn.iso_part1of2+UCSInstall_UCOS_7.0.2.20000-5.sgn.iso_part2of2 UCSInstall_UCOS_7.0.2.20000-5.sgn.iso
Step 3 Use an md5sum utility to verify that the MD5 sum of the final file is correct.
03dcc9defcef6ba3d1196ea4820c7eae UCSInstall_UCOS_7.0.2.20000-5.sgn.iso
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_0_2/cucm-rel_notes-702a.pdf
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Rob Huffman Sat, 05/16/2009 - 07:46
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Alexander,
Procedure
Hope this helps!
Rob
Correct Answer
  • Hall of Fame,
    Founding Member
Hi Alexander,
Procedure
Hope this helps!
Rob
