AIR-AP1231G-A-K9---Mesh
May 16th, 2009
Dears
I have these APs (AIR-AP1231G-A-K9) with 2.4 Ghz.I need Mesh Technology.Is it possible if i use modules of 5 GHz antennas and change IOS of APs from fat to lightweight and use controller.
Can any one please confirm? or give some suggestion.
Second can someone please give me the exact detail of this process (Part Number of 5 Ghz antennas etc)
Rob Huffman Sat, 05/16/2009 - 15:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Asif,
Q. Which indoor access points support enterprise wireless mesh?
A. Enterprise Wireless Mesh functionality is supported on the following indoor access points: Cisco Aironet AP1131AG and Cisco Aironet AP1242AG. It is not available on the 2.4 GHz single band platforms at this time.
From this excellent doc;
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps6521/prod_qas0900aecd806bde44_ns767_Networking_Solutions_Q_and_A.html
Hope this helps!
Rob
asif.naveed Sat, 05/16/2009 - 17:22
Dear Huffman
Thanks for response.Actually one Antenna of 5 Ghz in form of module can be inserted in this APs (as per my knowledge).Second Latest Mesh IOS of controller support this APs.I just need 100% confirmation so that i can make the design and other stuff.
Rob Huffman Sun, 05/17/2009 - 08:39
  • Hall of Fame,
    Founding Member
Hi Asif,
I have gone through the Release notes for many of the WLC versions and cannot see where any of them support the 1231 in a Mesh configuration. They support the 1231 as a Lightweight AP but not a "Mesh" AP;
Cisco Unified Wireless Network Solution Components
•Cisco Aironet 1130AG, 1240AG, 1522, and 1524 Mesh Access Points
Note This release does not support Cisco Aironet 1505 and 1510 access points.
•Cisco Aironet 1100, 1130, 1140, 1200, 1230AG, 1240, 1250, 1300, and AP801 Series Lightweight Access Points
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn521780.html#wp233793
Can you please link the version you are referring to, so we can check it out :)
Hope this helps!
Rob
