cant install ssl client on 3005 concentrator
May 16th, 2009
I have a working 3005 which I upgraded to 4.7.2p, and everything is working except I cannot upload/install the SSL client. I have tried several versions and I get the same result, the upload window hangs anywhere between 55 and 85%, and then unit reboots. The crashdump indicates something about malloc failed due to out of memory. I checked and it appears to have 25% available ram and well more then enough flash. The device has 32m total ram.
ryancolson Sun, 05/17/2009 - 14:17
thanks. I noticed that after posting =(. I have some ram on the way from good old reliable ebay =)'
